QUESTION: Macro variable maximum line length?
I would like to build a polygon command in a variable by appending one calculated point at a time to the string. This seems preferable to creating a set of numbered point variables of undetermined size. However I don’t know if macro string variables have a size limit. Could someone help me here?
SELBYL
andLTP2
to convert them thenSELBYP
to do anything else with it. (There is always a way but sometimes it’s less fun then you hoped.But maybe you should just write an XP instead of a macro? Then you don't have to deal with such restrictions.
CITY
command that can run or skip phases of the process so they can be done manually. In particular I’d like to construct an enclosed city wall around the map’s center with a more concise dialog. I’ve got the math worked out (I think) but rewriting the dialog would be tricky. (I want to use two-handled sliders for range values.)
