Inserting images in drawings
dragarhir
Traveler
I'm having problems inserting images in drawings. I can't seem to get CC3+ to insert the image in the correct size.
I have an image that's 3060px x 3960px in size with a scale of 6px/ft giving the map a size of 510ft x 660ft.
I created a map that's 510x660 but when I try to insert the image it is always bigger than the map frame. To be certain to insert correctly, I use the End Point function and use the corner end points of the map border. It always end the image below the bottom of the border as per the attached image.
What is the trick to get it exactly within the map border?
Personally, I recommend just turning on cursor snap when inserting the area, and make sure to use the inside corners. You can of course do the same thing usiing the endpoint (or intersection) modifier.
Or, a third option is to type the coordinates on the command line instead of using your mouse. The first coordinate should always be 0,0, and in your case, the second is 510,660
Thanks for the help.
