April Issue Inked Dungeons question. Map Guide shows wall shadows but drawing tool doesn't do it.
Hello all. Thanks to the CC crew for the April Issue Inked Dungeons. The Map Guide shows wall shadows by default but drawing tool doesn't do it. I checked the wall effects in the sheet and the shadow is checked. Am I missing something? Thanks for any help!
If they are, then check the size of the effect by going in to edit it. It may be set too small or faint to see.
I am using CC3+ with Crossover on a Mac. There must be some compatibility issue. sigh...
I'm ever so sorry, but I haven't a clue about the way Mac installations work. Remy Monsen might be able to help, but I know he's seriously busy teaching from home and probably fast asleep by now.
Thanks for any help.
- Right-Click the Cave drawing tool button
- click "Advanced >>" and choose the "Cave, Default" tool.
- Click the "Outline" button and then "Properties".
- Set the layer to WALLS and the sheet to WALLS*
- Clock OK twice and save the tool.
Note that does not fix the current drawing, but you can now simply redraw the caves and the shadow should be there.
That worked a treat for me, at least.
