Found a crash inducing option.
Was attempting to follow this tutorial; https://www.youtube.com/watch?v=h9F1Vp5CIFw At the step where he says to right click on the Grid button, I only saw two options, Standard Rectangular and Standard Circular. I wanted Hexes, so clicked on New, then 2d Hexagonal, Continue, change the 'unamed' to Hexes, or anything, and then click OK. And CRASH! This happened under Windows 10 (64bit) and Linux (using Wine (wine-5.0 (Debian 5.0-3)).
Also make sure you are on the latest update (Update 24, CC3+ version 3.93), and remember to re-install the update if you installed any add-ons after the update.
File -> New.
Select Cosmographer and 'Pick a pre-defined template - Next Button
First one I see is the Cosmographer Deckplan, I click that.
Right click on Grid, click the New button
Click 2d hexagonal, then click Continue. Then if you click OK or even cancel, it'll crash.
At least under Wine I can get a crash output, Windows just dies to the desktop.
Seems to be something weird with that template in particular, as I can reproduce the crash on that one.
Fortunately, since it seems limited to that particular template, you should be able to work around that problem by using the wizard template ('Decide settings myself') instead. I'll make sure ProFantasy is aware of this problem for the next update.
