CA2019_Setup.zip too large to download
I want to update my documentation files to include the index for the 2019 Cartographer's Annuals but the only way to do this seems to be to download the CA2019_Setup.zip file, unzip it and run the setup program. Unfortunately every time I try to download it fails before it completes. Since I've already installed every issue of last year's Annual individually (something I suppose most subscribers have done), couldn't you provide a compact download that assumes this and only updates the documentation?
Do you have Download Manager? I used to have all kinds of trouble before I got it, but now (and even though I am on mobile broadband, which is notorious for suddenly cutting off in bad weather and when their are too many people using their phones in town) I haven't had a problem since I installed it.
I probably shouldn't advertise other software on this forum, or advertise any particular one when there are probably several, but this is the one I use. Totally reliable - never once let me down.
https://www.internetdownloadmanager.com/
There's a 30 day free trial. If you don't want it for anything other than this you can have it for free. I think the price of a lifetime licence for one machine is now £19, or $24. Not bad for a tool that never fails.
Here is the control panel where I've just started downloading the very same file. As you can see there is a resume capability (saved my life a couple of times), and it makes use of all the processors - downloading the file in a fraction of the time it would take if you just did a straight download through your browser. Downloads of this size would have taken me about 4 hours before I got it. That makes sense, since its now using 8 connections instead of just the one. It says it will take about an hour, but that's understandable because I'm using a 3D modelling suite in the background, so the processors are busy multitasking that with the download. This, however, never seems to cause any problems.
That was my fault.
Sorry!
I did 3 of the issues, and all 3 of them were around a GB.
And there are always some little corrections, but if you have kept the setup files in a separate folder like I have (and which you should do in case you need to start from scratch again), then of course you can use the individual setup files.
Im sure it will be solved soon.
I downloaded the 2018 Annual today (again) and discovered that the file size had changed since my last download.
So my conclusion was that the file had been updated meanwhile...
...and did a re-install.
When trying to install the 2019 Annual afterwards I got an error message that told me that my CC3+ version was to old for the install - though I had installed the update 24 earlier.
So the Annual 2018 install seems to replace some newer files...
A new update 24 install was needed before the installation of Annual 2019 worked.
Got bit some years ago at university not having a backup file for a 5 page paper I had done. Floppy died, and my 're-typing from memory' only got me a C. Sigh.
So I have plenty of backups. On my USB external drives I have folders with the date on them, and in that are downloads, maps, etc.
