Problem importing FT map into CC3+
I'm working through tutorials and such for FT3. Really enjoying my time, thank you Joe for making it!
Trying to import my world into CC3+ by "Save Campaign Cartographer file", choosing coastline only. When I open the resultant file in CC3+, it's blank. Distance measures though... So I'm thinking maybe I just can't see the map for some reason?
Anyone else run into this? I'm fully expecting to learn that I've done something wrong.
Sometimes the map isn't visible because CC3 opens it viewing just the corner of the white border.
If that doesn't help it may be that you have exported the map at a resolution that is too high for the crinkliness of your coastline. You might need to edit the export setting to do it at a lower resolution if that is the case.
