Mac OS Catalina
Just to let you all know that there is a new version of crossover (wine) version (19) that allows 32bit applications to install and run , i have tried this on parallels virtual machine running catalina and CC3+ installed and ran fine , i would guess that all the other profantasy software would also be good to go
macos catalina has no support for 32bit applications
Rob
Rob
I'm pretty new around here and I've just upgraded to a new Mac running OS Catalina. Unfortunately, I didn't do my homework to realise that it is 64-bit only, and as a result Adobe CS4 no longer runs and I refuse to pay a subscription for a program I use infrequently so I've just purchased the Humble Bundle which includes CC3+, City Designer, Dungeon Designer, Battlemat & Floorplan Collections, Token Treasury, Perspective 3, Source Maps; Castles, Temples, Tombs & Catacombs and the Tome of Ultimate Mapping, whew.
I've also downloaded Crossover 19 to run the software. I assume I would have to install CC3+ first but I'm not sure how to set it up in Crossover and then how to install the add-ons and so on.
Any suggestions?
i use a windows 7 64bit bottle
to install additional programs like DD3 you would perform the same procedure as above and select the same bottle you installed the cc3+ program into
once everything you want has been installed i would export this bottle to archive and keep it somewhere safe just incase you need to reinstall in the future which would just be an import of that achive
hope this helps
Rob
Install went well except City Designer 3, Source Map Castles, Source Map Temples, Symbol Set 2 and Tome of Ultimate Mapping failed with a CC3+ not found, error. The other .exe. files worked fine and I followed the exact same procedure. Should CC3+ be running when these add-ons are installed?
Cheers,
