CC3+ error reading general settings file
When I start CC3+ is gives me three warnings about reading general settings files. I looked in the filepath and none of the files are there. They are CC2PER-General.opt, CC2PER-Houses.opt, and CC2PER-Colors.opt.
I'm using SS5. I used the random street, SS5C Tiled Roofs and those two orange houses appeared without roofs on them. Also the wall doesn't seem right either, is that how it's supposed to look?
First you need to make sure that all the fills are imported. You can do that by creating a new SS5 map and saving it somewhere, then inserting it to your existing map using Draw->Insert File, but you don't have to actually paste it. Just starting the insert process is enough to import all the fills.
That may actually remedy the house problem in itself, but if it doesn't I'm not exactly sure how to do it. Remy (Monsen) would know, but I suspect he's gone to bed by now.
To get the right drawing tools simply click the SS5 icon in the bar across the top of the window. That should also give you all the right symbol catalogues as well.
You're welcome :)
