Right click option missing
I somehow lost my right click options. For example, I would normally click erase, pick an object, and right click Do IT to complete the erase process. Now when I right click, I get a command prompt. Any ideas how to get the right click options back.
John
John
When I try to select an entity it seems to be selecting the entire layer or something else but not the entity I wanted to select.
Solution
This can happen sometimes if a command or macro gets aborted. To fix it, got to Tools >> Options and click on the Select method button. Make sure that "Dialog or Pop Up" is the current method, then Click OK.
Hope this helps someone else.
