New Guy Mapping
Ok looking for tips tips from some vets here. I posted a map earlier got some feedback and tips on how to scale it right for a world size map that I want to use to make smaller continent maps to country maps to area maps etc. (So I can keep hex scales accurate etc. I wanna do this right one step at a time so I don't have to go back to the top and make a ton of changes. So here's my world size map b4 labels etc. Any tips or advice before I move on? What should my next step be? (I'm guessing it's mark off a continent, crop and trace it for a new to scale map and start adding details via symbols, smaller rivers etc?) Some guidence from those who have been through the world process would be appreciated.
- Always remember the size of the things you are working on, it is often easy to loose sight. For example your continent in the bottom right corner is about half the size of the continent of Africa on Earth. However, even if your continents are smallish compared to earth ones, that is still a REALLY HUGE area. Consider that when adding details.
Remember, you can always use the measurement tools from the info menu to measure things in your map, this really helps keep things in perspective
- When you make higher details maps (such as the continent maps), make sure to keep the current scale, don't cale the landmasses up or down.
For the current map:
- You could probably add a few more details to it, especially some symbols. Keep in mind that a symbol is intended to show what is there, and not being an accurate scaled representation of the feature.
- Your effects are really weird. I recommend you reset them to default (Simply re-select the Overland CC3 setting from the effects preset setting)
Not sure how to "measure correctly" on such a large scale nor how to copy everything in the cropped area. Seen a video where a frame was inserted then a lot of trimming etc was done.
Greg
As for measuring, all you have to do is to use the distance tool in the info menu to measure between two easily recognizable points on the source map on (preferably on opposite sides of the landmass), and then measure between the exact same places in your destination map. If the numbers comes up equal, the scale is correct.
To get to instances of CC3+, just start a new instance form the start menu/desktop icon.
