CC3+ keeps crashing when I try to trace a file or when I try to save after I change a node or even when I am trying to change a node. I have Update 23 installed.
One way to reduce the number of nodes is to use TRACED and specify a larger value for Simplify Distance. The default value is often too small for complex trace values.
Seeing an example of the image file that you're trying to trace (as well as some information on its dimensions) would be very helpful, as Loopysue suggests.
Or are we wrong?
How about a screen shot of the map?
