missing check boxes
Hi all -
According to the help text, the Global Layer Status dialog box should let you show and hide layers with some checkboxes. I don't see the checkboxes - see my attached screenshot. After clicking in the space where some of the checkboxes should be, I've managed to hide some layers. I can't see which ones are hidden and which ones aren't in the dialog, since I can't see the check boxes. I just started using CC3 this week, and after an hour of playing around I'm pretty well stuck thanks to this. Any help would be greatly appreciated!
Edit: I should note that I am able to see the check boxes in the Select Layer dialog. I figured out how to remove the layers from the Global Layer settings and just use the local layer settings for a map.
