Problem file doing wierd thing on open - SOLVED
Loopysue
ProFantasy 🖼️ 40 images Cartographer
This file was ok earlier today, but when I open it now I am immediately asked to pick a fill style before the map even shows.
[Image_13224]
It doesn't matter if I pick one, or cancel the dialog, the next bit is always the same.
I want to change the fill of the stone texture patches behind these craters I've drawn, but when I use change properties I get as far as this
[Image_13225]
And then CC3 crashes.
[Image_13224]
[Image_13225]
I will attach it to a whisper for you below, since it is a commission piece.
Thank you so much for sorting it all out for me, Joe!
