Error 00000007E loading XP module: Effects.dll
I finally get the cc3+ program to install without error messages saying five files couldn’t be loaded and then I get the above message when I try to open it. I saw another post just like this but since I have windows 10 the fix mentioned there won’t work. Any ideas?
Try to manually install both the Visual C++ 2013 and the Visual C++ 2017 redistributable packages. You need the 32-biyt (x86) versions of both, no matter your OS version. If they are already installed, just let them do a repair install.
These are normally installed along with CC3+, but some computers have problems that cause these components to fail to install.
Please contact Tech Support with your issue. I have just described how you can do this on the other thread where you raised your concern this morning.
