CC3 toolbar messed up
I've got CC3, CD3 and DD3 installed. Something happened the other day and now I've got icons for all the other Addons on my toolbar even though I don't have any of these other addon's added.
Furthermore, none of them work! Even the ones I do have installed. If I click on any of them it gives me a message saying that the approprate tool "could not be loaded"
Any ideas what I can do about this? Will installing the patch 7 overtop correct this?
I was afraid I would have to uninstall/reinstall and i've created a bunch of sub-folders for various mapping projects and didn't want to risk loosing any of it.
I've searched the forums for all threads mentioning "toolbar" or "mnu" (for the menu files), and none have an answer. I tried running CC3MenuConfig.exe but as far as I could tell, that did nothing (TaskManager also showed nothing start). My borked-up FCW32.MNU is attached, should anyone wish to risk blasting their sanity...
I've got CC3, CD3, DD3, and SS2V3. Could some kind soul copy the contents of a working FCW32.MNU here so I could fix mine without having to manually edit hundreds of lines and figure out which buttons are missing?
Thanks.
Thanks,
Steve
Note that if you use a dual-screen setup, tips only show on the primary monitor.
Steve
I have Vista Home Premium. 32-bit.
