Weird Behaviour Pt 2
Second odd behaviour is this:
I also wanted to add some texture to the land, and changed the fill style to "graasslands dark green", which made lines appear all accross the drawing see attached).
Any thoughts on this would also be useful
Thanks
Stu
Thanks
Stu
However, if you were to explode the land (the button with the stick of dynamite on it), you could then use the SIMPLIFY command to reduce the density of nodes just a bit and try re-mulipolying the land after that. You do that by clicking the MultiPoly button on the right toolbar and selecting all the land.
Its not a guaranteed solution, but it may reduce the number of those lines. If you are lucky they might all disappear.
That landmass was in fact 1 entity, due to the way exports from FT3 seems to export things.
In the end I copied all the outline entities (which were all separate) to the land sheet, so that they were all individual entities.
It has removed the line issue, but it has slowed zooming in and out down quite a lot!
S
It might be a good idea to do that before you really get into the rest of the mapping, since tracing that coastline each time you want a desert or a forest to meet it is going to take forever, not to mention the fact that adding more nodes on top of that already rather large load will only make it slower again.
