Cosmographer Problems
Hi,
I seem to be having a lot of problems with the Traveller world satellite map,
1) I can't seem to delete the “World Name” text
2) When I add text (on the text layer) using the text button the text dissapears after pressing refresh, both World name & UWP.
3) This is happening on both my laptop & desktop machine.
Any thoughts?
Any thoughts?
2) Make sure the text goes to to the TEXT sheet, and that you don't have entities on sheets later in the drawing order that could cover it. Entities that disappear on the first redraw are always down to sheet issues, either the entitiy didn't go to the sheet you though it would, or your sheet ordering is in such a way that the sheet containing these entities is behind something else.
I havn't done anything else to the sheet, or layer, as this is the first thing I want to do, adding the Name & UWP.
So I can now delete the highlighted objects but still can't seem to get my text to stay on the map.
Then I click on World Name, and the text edit popup comes up. Enter new text. Click okay.
Its a gray text which I do a changec on to change it to white color 15.
JimP's solution is workable, but I think I'll just add text via Photoshop as it has to be resized anyway.
thanks
