Help isn't so helpful
Select 'Sheets and Effects' - select 'Text' - check 'Active Sheet Effects' - select 'Add' - select 'Texturize' - Select 'Help'
Get error (see attachments I am currently assuming I can add)
repeat everything above.
Don't get error. Get help on Texturize instead
"This is a placeholder for the Texturize dialog help."
Thanks for reporting this. Unfortunately there isn't much the community can really help with this, I recommend you contact ProFantasy directly about the issue itself.
If you still need help on the texturize filter, the help information for it is actually stored in the Effects Listing help topic (which should also show up when you search help for texturize), as well as in the user manual page 72
