How do I line up bitmaps seamlessly?
So I just got CD3 recently and have been scanning the documentation and fora without any luck.
How do I seamlessly join two bitmap symbols easily?
For instance, I want to use the "walls" sections in the bitmap symbol catalog. I cannot find a way to get them correctly aligned without zooming in. This is very clunky and I suspect there is a better way. Thanks!
    I'm not familiar with these particular symbols, having never used them, but normally symbols of this type (where alignment is desirable) are designed to be a specific length, like 5 or 10 feet long. If they are a specific length it then becomes possible to use the snap grid to align them. If it works that way with these symbols you will need to align a whole string of them and group them together then rotate them if you want a wall that is other than horizontal or vertical.
    I may be way off track with all of that Because I don't know these symbols I don't even know if they are 'smart' or not.
    I have had to sometimes turn off snap, and just use Drag to move something like that crenelated wall to the rest of it. Zoom in as well.
    Most of the time, snap is the best solution, but those particular symbols are not very well-aligned. I found that with a snap setting of 5' with two divisions, they work reasonably well, but not perfect. I suspect the original artist of those particular symbols didn't have grid snapping in his mind when he made them.
  • <blockquote><cite>Posted By: Monsen</cite>Most of the time, snap is the best solution, but those particular symbols are not very well-aligned. I found that with a snap setting of 5' with two divisions, they work reasonably well, but not perfect. I suspect the original artist of those particular symbols didn't have grid snapping in his mind when he made them.</blockquote>
    I messed with the grid some more this morning and discovered the same thing. It's a shame, too, as that style of wall illustration works a lot better for my needs than the vector-and-effects approach.
