Change path of background picture?
How do you edit the path of a picture used for background? The link is current still valid, and the map works, but I want to do some housekeeping and move the file elsewhere. Because the map works and there are lots of things placed over the image, I would not like to redo it from scratch.
The info for the item is shown in the attachment.
What is the best practice for putting background pictures in places that won't get broken by mistake?
Thanks in advance,
Bryan
Thanks in advance,
Bryan
Best place to keep pictures is either in the same folder as the map (so you can use a map-relative ($) reference) or in the CC3+ data directory (so you can use the data folder (@) relative reference). These places will always exists, even if you drastically change your file system setup in the future (while you may not have the drive letter E: available on all your future computers)
