Selecting single entity when stacked, and outlines
Hi, I've got two questions that I think are relatively simple, but can't find an answer in the help.
I recall sometime ago reading about how to select a single entity when there are two stacked on one another. For example I've got an outline and a filled shape that are right on top of one another. How do I drop the one I don't want from my selection of 2 entities?
On a related note, if I want a visible outline of an entity, say an outline along the coast or body of water, etc... what is the best way to handle this? Do I copy the entity and make the new one just an outline and change the color? Or is a sheet effect the preferred way of doing it?
Thanks in advance !
Thanks in advance !
You can also use the difference in properties.
After selecting both (all) entities, right click, select Combine -> And. Right click again, select for example color, then select the color of the entity you wish to keep selected from the color bar (Or right click to bring up the full color picker). You'll notice that only the entity with the matching color is kept.
To create an outline, the simplest way is to use the Outline Tool
For single entity editing commands it's a bit more tricky, They will select the first in the database (lowest in the stack).
If you select a single entity, the default is that the first one in the database (the lowest) is selected.
