More perspective work...
![Joachim de Ravenbel](https://i216.photobucket.com/albums/cc13/JoachimDeRavenbel/th_jdr68_zps48992fbd.jpg)
Hi !
My daughter needs a pyramid map for one of her university project and because I'm stuck at home after a knee surgery gone wrong, I was able to produce the following map.
All the fill styles are home made, and so are the columns and tomb symbols.
The pillar hall was quite difficult to render due to all the shadows. I used a 3D software (POV-RAY) to generate these shadows.
Edit: found some glitches in the images...
That's just gorgeous
You have the luckiest daughter!
Sorry to hear about the knee surgery though, hope you get better soon.
Sorry about your knee, hope you'll get that in order soon.
I mainly used a simplification of the article here.
The simplification was in using wall sections that match the fill styles. Because the bitmaps where imported to a 10x10 fill styles, walls have lengths of 5, 10, 20, 30'...
In fact, you can achieve the same result by extruding 10' long lines (without using the complex part of moving the fill styles origin points as decribed in the article), and placing them next to another, like connecting symbols (see below).
As for the knee, well, recovery should have been 4-6 weeks long and I'm now in the 10th. At least I can walk, err... limp, but it's still hurting.
Willing you well again
Good Luck with the knee !
Nuff said.
2) Tech question: how did you get the jagged cutouts on the walls and ceilings?
This is awesome, btw!!!
