Merge shapes for a single outline
clithgow
Traveler
I'd like to merge multiple shapes (as an example my circle & polygon shown here) so that I can apply a single outline and fill to them? Basically I'm trying to create mostly rectangular landmass with round turreted corners in a city plan (specifically this one here )
I know how I'd do it in AutoCAD - funny how knowing one CAD software can both help and hinder learning another.
You can trim them both at the same time by using Edit --> Trims --> Trim inside.
Watch the command line. It asks for two trimming entities first. Pick both your shapes. When it starts to ask for entities to trim pick first one then the other of your shapes. That should trim the outlines to make one shape.
To combine those shapes right click the Fractalize tool and pick Line to Path. Then select both the shapes and right click and do it.
Converting them both at the same time while their ends are in contact like that should convert them both into a single unified shape.
Some info about the command in this blog post. It talks about using it on raster image, but the exact same technique applies to using it on regular CC3+ entities.
Sue - That worked great as well, that LINE TO PATCH was the trick I was missing.
Thank you both!
