FCW file that is having issues when loaded
I've got a map I've not opened in a while. It's a rather large map (Barrowmaze, flat mega-dungeon versus deep) and when open it in cc3+ (3.90) CC3 will give me "Not Responding". There will be short windows where I can click on a option (like toggle a layer's visibility) but it takes about 1-2 minutes to get a response to each response for that.
I can load other maps and not have issues.
Watching my windows resources it doesn't seem like it's using an extraordinary amount of memory or cpu (or disk activity) and certainly not all of them.
Anyone have a theory on what might be causing this?
I can't remember if the version number changed between 20 and 21, but 21 made a whole load of difference for me - all things faster and more stable.
https://i.imgur.com/HZgiZzM.png
Am I missing an update?
Have you tried running it again as a repair (Update 21, I mean)
And don't forget that you need to right click and run as Administrator.
If you are unsure about reinstalling it (basically just running it again in repair mode - its called Update 21) maybe it would be advisable to raise the matter with technical support?
Unless, of course there are others here with a better understanding than me
https://i.imgur.com/MCpIVM5.png
