Changing bitmap from VL to H
I was doing a map in SS2 and noticed that I could change the bitmap fills from VL to H simply by going to the fill manager picking the tile and once in the folder double clicking on the appropriate tile. This made the map look right when it didn't with the VL fills. I tried to do the same thing in a map I was doing in SS4 and it did not work. The tile would not change and stayed at VL. I had to change the resolution from 20 to 40 to make it look somewhat good. Is there a reason why this worked in one map and not in the other? Map size perhaps?
