Is there any way to reset the drawing tools after they've been jacked up? My forest drawing tools crash CC3 every time I try to use them but only on this map and I don't know what I did to mess them up.
You can always run a repair install over CC3, which will reset all drawing tools to their original version (apply the Patch again aftrewards). But this will not help if the problem is in the map - which is likely when it only happens in this one map.
I can't say much more without seeing the map itself. I'd suggest contacting tech support to get help with the map.
