CC3+ partially freezes upon executing FILE command after reinstall of 2007 annual
Hi all,
I've run into a spot of bother with the modern city mapping style from the 2007 annual running in CC3+, in that it runs a lot slower than it did when I used it in CC3. Every redraw takes about 2 seconds, whereas before it was instantaneous. I figured I should reinstall the whole annual, which not only didn't correct the issue (I'll probably create a new thread for that after this issue is solved), but also partially freezes my CC3+ when I try to open a different map file.
I will load a new instance of CC3+, I can interact with the map fine, but after going to File > Open, the program hangs. It doesn't do anything besides changing the contents of the command line, I can't interact with anything in the program, etc. However, if I hit escape, the program is restored and I can once again continue to click around in it. I appear to now be locked out of any other map files I have. I am running version 3.84. Has anyone had this issue before, or have ideas on how I can solve it? I have restarted my computer to no success.
Thanks!
Thanks!
Also, if you open up another map in another directory using OPEN, and then try the FILE command, does it work?
yes, the FILE command doesn't work regardless of what directory the map is in.
What's more - I was going to export a small section of a map to show to a friend this evening, and when I attempted to do so (the command line reads EXPORT), I found out that the program hangs in much the same way that it does with the FILE command. A brief test revealed that these are the only two functions from the file menu designed to open a new window that hang instead of performing the necessary action.
Do note that uninstalling will only remove the files the installer put in, which means there might be files left in the data directory. For a proper clean reinstall you should uninstall everything, then remove your data directory (c:\ProgramData\ProFantasy\CC3Plus by default) [renaming it rather than deleting it is better so you don't risk deleting something you wanted to keep] and then reinstall everything. (Or instead of removing the data directory first, change the path in the installer when reinstalling to use a different path than the default, just throw a number at the end or something)
Yesterday I thought that maybe the commands *were* being executed, and the program was just taking a really long time to do so, so I had the idea to move the program into my other monitor, execute the FILE command, and let it hang indefinitely while I went about my business, and strangely enough the problem is no longer cropping up. I can both open and export files without any issues now.
I don't really know what happened there, but good thing it fixed itself, I guess. If I encounter any further issues I will send a ticket to PF directly. Thanks all.
CC3+ may also want to remember where you had last dragged your child window and its state, so you may need to watch out for that as well.
