Created & Saved in CC3+, Opens in CC3
I have a group of maps that I created in CC3+. If I open them from the hard drive, they open in CC3. To Open them in CC3+, I have to start the program from the shortcut on the desktop, then then use the Open command under File.
This is not a big deal and I can live with it, but there is a limit to my patience and I fore see a day when it will be a big deal.
Any one have any ideas?
Thank You in advance.
So the quick fix is just to start CC3+, then close it, and maps will start opening in CC3+ until the next time you manually start CC3.
If this behavior doesn't work for you, it means that something on your system is preventing the registry writes that program does on startup to "claim" the file type. You should be able to manually override this by right clicking a map file, choosing properties, and on the general tab, hit the Change button to select which program to open the file in. You may need to browse for the correct version by going More apps and then look for another app on this pc at the bottom. The file you are looking for is the fcw32.exe file in c:\program files (x86)\ProFantasy\CC3Plus
