FT3 export to CC3+ stopped working
Hello.
I recently purchased, amongst others, CC3+ and Fractal Terrains 3. I've been doing tutorials since, to get a bit of a grip on both programs.
On the 13th of this month, I was able to create a world map in Fractal Terrains 3 and export that with a Full export function to CC3+. Upon opening it, it displayed literally everything (was to be expected). No problems there. I decided to export that same map from FT3 a few more times with different settings and such.
Now, today I created another world and wanted to do the same. However, each save as a Campaign Cartographer 3 save results in a completely blank, white map. I have tried the various export settings but the result is the same each time.
I have already tried hiding each sheet one by one, because I thought perhaps something went wrong in one of these, but that didn't work either. Then I tried doing it with the layers, but no joy there either.
The original map I saved as a CC3 file on the 13th is still accessible in CC3+. Opening other maps already in CC3 save format is also possible, as is creating new maps. But it simply appears impossible to open any recently exported ones.
I did a quick search regarding this problem but was unable to find anything related to this. If this is an already resolved problem, apologies for creating a new post.
*edit: I have meanwhile continued digging and found out that in the map notes, the already exported map reads "Symbol Scale: 9.09" while the newly (malfunctioning) saves read "Symbol Scale: -nan(ind). I have however no clue as to how to get that solved.
*edit2: I have done a full reinstall of everything. Removed all CC3+ and the addons entirely and Fractal Terrains, deleted any lingering settings and still, it exports only a white sheet.
*edit3: It appears I have solved the problem, but I do not know why. I opened the projection window and changed the projection. Once I did that, Campaign Cartographer was able to load the export. Once I reverted back to the projection it was on, CC3 was also able to open that projection.
I am keeping this open for now in the hope that someone will be able to explain what the problem was. I do note that the save now has a symbol scale attached to it, but I do not know why it went broken to begin with. And I'd very much like to avoid this in the future if at all possible.
I do feel kinda dumb now that my first post on here is this...
