VCOMP120.DLL is missing
I keep getting a FCW32: fcw32.exe - System Error message.
This file is in my System32 folder.
I installed as admin.
I re-installed trying to repair it and no luck.
Can anyone help?
    The file in question is part of the Visual Studio 2013 redistributable package ( https://www.microsoft.com/en-us/download/details.aspx?id=40784 ). This package should have been installed as part of the installer, though. Have you downloaded the most recent patch from your download page on the ProFantasy site?
    Note that if you manually download the VS redist Joe linked you to, make sure to get the 32-bit version (x86). CC3+ is a 32-bit program, and require 32-bit libraries even if youhave 64-bit Windows. (Also note that the one in your system32 folder is also the 64-bit version (unless you have a 32-bit Windows install, which is unlikely), so it won't do CC3+ any good)
  • dl'd the studio and it worked. thnx for the help.
  • 1 year later
  • edited March 2020
    If you getting vcomp120.dll missing file error the reason could be any of the below:
    The invalid entry of vcomp120.dll in your system’s registry can cause this error.
    Missing files can make this error appear on your screen.
    Even if the file is corrupted you will see this error on your screen.
    In case of hardware malfunction, this error will appear on your screen.
    To fix vcomp120.dll you can try the restore way by restoring vcomp120.dll file or you can download Visual C++ Redistributable Package. For a brief solution visit
    https://coding.fm/vcomp120.dll/
