bug with fractal options in CC3+
Hello all,
I am attempting to make a new overland map with CC3+. I get into the options for the land mass and then advanced options. I click on options for the fractal and it crashes to desktop. I tried it several times and it does the same thing. I have all the addons installed in CC3+.I do have CC3 installed as well with no addons and it works fine in there. I know I am leaving a big open door where problems could be so sorry about that. Does anyone have any idea as to why it keeps crashing to the desktop? Thanks in advance.
"What a nice night for an evening." - Steven Wright
Does it only happen with that tool? If not, does it also happen on another type of map, like a Dungeon cave tool?
edit: I checked all of the other 'Draw method' to the left of options. No crash.
Ciao,
Ralf
EDIT: reason for asking is that the 'Profantasy' folder usually found in ProgramData is created during installation. If you can run the app at all then the 'Profantasy' folder must have been installed elsewhere. The app won't run without it, since it contains all the graphics, menus, symbols... practically everything.
Maybe you can find it by doing a search for it on C drive?
So you need to find the Profantasy folder by searching on the other drive
Here is a screen shot of the approximate contents of the folder so that you get the right one.
Glad to hear you found it!
https://app.prntscr.com/en/index.html
You did the business end of things. Jim and I just kind of nudged a bit from the side lines
