Saving selected areas
I would like to select certain areas of my world to work with in detail in CC3 as pngs. I can blow them up, but saving the selection I end up with a blank white area surrounded by black as my 'file'. What am I doing wrong?
1) ctrl-A to get the save as menu.
2) select rectangular png and type in a filename. Click save.
3) click left mouse button upper left corner of area you want.
4) move mouse pointer to lower right of area you want to save. click left again.
file saves. Look in folder you saved to.
I tried the above steps on a different map, works for me.
Are you accidently touching other keys at the same time ? I do that as well.
I just checked in FT3, and the 'save as rectangular png' isn't available.
Save the entire map in FT3 to your hard drive.
When saving a png from FT, you just need to zoom in to the area to export, it doesn't use the selection, but instead the current view.
