Info > Distance Behavior Changes
So I've noticed that depending upon what symbol style I have active, the Distance command gives different types of results. If DD3 is active, then the command gives a straight line distance. If SS4 is active, you get a more detailed results window, that has an X & Y distance.
I like the SS4 style symbol, is their a way to always get this type of measurement? Or a way to get this type of result when I have DD3 active?
Yes please!
Did you just know that or was there some way us mere mortals could have figured that out?
Or you could just look at the menu files and see what commands the button/menu item is set up to call.
And thank you too, LE - I wouldn't have gone digging around the menu files for no good reason while I'm fairly busy right now, and wouldn't have known about this unless you had mentioned it
