HIDDEN LINKS layer missing
After a 5 year gap from mapping I just reinstalled CC3+ , CD3 ect...
At first CC3+ seemded to work fine.
But after installing CA3 or CD3 (I forgot which one) I get an error when opening CC3+
A message box pops up that says there is no HIDDEN LINKS layer.
Everything seems to work fine but its annoying.
Help would be apprciated.
Did as you said.
Still have the problem.
Did a bit more testing.
Only seems to happen if I go to one of the addons (CD3, CA3 or DD3) and then go back to CC3+
When I press the CC3+ button I get the error.
I've used a new map, old map, sample map. Will keep playing with it.
Unzipped and copied the file into the mentioned folder but the problem is still there.
1. I uninstalled my previous installation and then manually wiped out all traces off the disk (the uninstaller left a lot of files).
2. Redownloaded the CC+ installation and installed it. I confirmed I had this same issue with a clean install.
3. Even though my version in Help>About was showing 3.84 I downloaded and installed the 17a patch.
4. All my problems were solved after the patch.
