Edited Symbols Effect Problems
I've edited a few building symbols by adding a shape on top to create a black/white symbol. This is for a Middle-Earth CCG map in case you are curious. However, when I apply an effect to the symbol, my addition goes away.
I'll attached before and after pics to show what is happening. The icon at the bottom left is the one that is affected. Any ideas?
Thanks,
Daniel
Thanks,
Daniel
Its best to give new symbols unique filenames. For example, if you have "Tower 01" in the original set, you might want to call your own version "Tower [your initials] 01"
EDIT: I was referring to the actual png file names, not the names of the symbols that appear in the Symbol Manager (which can be different to the filenames). To keep things simple I would recommend not changing the names from within the Symbol Manager, as that may prove to be confusing if you come back to this map a few months later.
-Daniel
Unless you created the catalogue in a way far removed from the way described in the Tome, it won't be that far away from the folder containing the symbols.
Maybe locate the folder containing the png files (which should be somewhere in the Symbols folder), and look for it in the near vicinity?
It would help if you could remember some or all of the catalogue name.
