Reinstall issues
I recently had to format my hd and reinstall windows which means I had to reinstall CC3+. CC3+ works fine.... but before the re-install I had a column of buttons on the left side that had the sheets on it. That is no longer there. Also the buttons were higher res then they are now. Looks like they are 16 bit colors at the moment. Can anyone direct me on how or where to look to fix this? I've looked and am unable to find anything. Any help is appreciated. Thanks in advance.
Sorry rambled on and on again... I do that from time to time. :-(
Back to your regularly scheduled forum discussions.
If you installed them to separate directories, you may be ok, but it's still a bad idea to install an old version after a newer version was already installed.
I do agree with you that installing all add-ons can be a pain in the back, but it's not supposed to happen often, so I'm not sure if PF will want to change it.
If the whole toolbar is missing, check your configuration by clicking the Screen Tools
I hope that helps but, if not, check back and we'll see if we can provide other suggestions. Do you have a screen shot of the current interface?
Cheers,
CC3 is first
