Mercator Revised doesn't show Original Mercator symbols
Hello,
the Mercator Revised Mapping Guide (2017 Annual) reads: "If you do own the Annual Volume 1, those (Mercator Historical) symbols will be available in this style too.
I do have both style installed, but when I start a Mercator Revised map, the loaded catalog only shows the Mercator Revised symbols. Mercator Historical symbols do not show (unless I manually change the Master Filter, but in this case the Mercator Revised symbols disappear).
Am I doing something wrong, or is there some setting I need to change?
Thank you
Thank you
