Well, update 15 didn't work out so well for me
I installed update 15, and now all my existing maps appear blank. They're not, but I only get a blank white screen. (It will be blank green when it first starts up, but as soon as I do anything, it turns white, and stays that way.)
If I go to Info and Count All, I am told there are a lot of things on the map. But Count doesn't appear to do anything.
However, if I select an object, sometimes it appears, but not always. Redraw does nothing. Mostly, all I get is a blank white map. I've tried hiding sheets, and mostly that just turns the map into blank green instead of white. It also freezes up occasionally.
I reinstalled the update, no change.
If I start a new map, everything appears normal, though.
Did I miss something about this update, or should I contact tech support?
If it crashes on launch I think it might be related to a specific style that's auto opening, to fix it I renamed the file so CC3+ would open something else. That seemed to work.
Don't try and use 'Issue 15 - Heraldic Symbols' it's causing a crash.
Upon further tinkering, there are some maps that open and display OK. I think it might be related to links to imported symbols or fills.
Guess that's what I get for being lazy.
