So how do you guys make lakes?
I'm using sea fractal polygon and it keeps ereasing the work, can anyone help me out?
  • Generally speaking, ocean objects go on a layer that is underneath the land layer, where lakes need to go on top. (Layers get rendered in the order in which they appear on the list, top to bottom.)
    If you hide the land layer(s) until the land disappears, I suspect you'll find your lakes underneath. Then you can move them to a different layer that's below (on the list) the land layer. (You might want to create a layer for that, or there might be one already there that's suitable.)
  • ScottAScottA Surveyor
    You have to be sure that lakes go on a sheet lower on the list than the land sheet. The sea fractal polygon you are using is probably set to automatically go to the background or sea sheets near the top of the sheets list, so the land would hide them. You need one below the land sheet (its actually upsidedown -- those sheets higher on the sheets list are lower in your map -- the map draws from the top down, each subsequent sheet going over the one before it).
    Agreed.
    What I do is this:
    sheets
    Sea
    land
    lake
    symbols
    text
    Sea gets drawn first, text is last.
  • Sheets sheets sheets! Not layers :)
  • Is there a Lake Fractal polygon? I've been using the sea for it.
    Most map styles have a lake tool, precisely to get the sheets correct. If it is fractal or smooth depends on the style (Some have both). Using the sea tool is fine too though, it is just that you need to fix the sheets manually after placing it like explained above.
    If there's a lake tool it will usually be in the rivers drawing tools menu. Look there.
    edited March 2018
    If, for some reason, there is no lake tool, you can quickly make your own. The easiest way might be to save the sea tool with a different name (e.g. change "sea" to "lake") and then edit the newly-saved tool to use the RIVERS sheet, LAKES sheet, or some other sheet that sits above the land. For details how, see Monsen's excellent Command of the Week series posts, Managing Drawing Tools (Week 20), and Automatic Sheets for Symbols and Drawing Tools (Week 46), and/or read the informative Drawing Tools section in the CC3+ User Manual, starting on p. 86. It includes sections on editing and creating drawing tools.
    Cheers,
