Did NOT want Grid to export from FT to CC3+
For some reason, whenever I export a FT map to CC3+, I always get a 30-degree grid on the export centered on the equator. Even though I do NOT have a grid defined in the FT map! I've confirmed this by checking the Grid settings in FT (there are none defined).
I have a feeling I'm overlooking something simple... does anyone have an explanation?
I haven't done one for a good long time, and I'm a bit tied up with Blender rendering at the moment, but I seem to remember you can edit the settings of the exported map before you export it.
Which export type are you using?
If you click the edit button and page through to the last page on the editing boxes, unticking the grid option should do it.
