Importing vs Opening PNGs
So I've noticed that their are two ways to bring in PNG files as symbols. One can go through the Symbol Import PNG process and get "proper" symbols made, or one can simply open the PNG file from the symbol catalog open option.
What are the advantages of one versus the other?
If you've just done the open method, is their a way to "convert" the symbol references to the other? (If their is a need to do so).
A symbol catalog also have lots of other settings that help the symbols work correctly, like automatic sheet selection, cutting symbols, random transformation and random collections, and more. None of this is available with images form a folder.
An image inserted this way is no different from a symbol though, a symbol is automatically created for you when you do this. However, note that in addition to the properties mentioned above, a symbol isn't always just a single image. It can be made up from multiple images, or it can contain other entities, like a CD3 house which contains multiple entities to make the house work properly, it is much more complicated than just the actual image of the house.
Personally, I prefer to always work with proper symbol catalogs, I never use the ability to open a folder of pngs. (There is nothing wrong with doing that though, it is a perfectly fine workflow, it is just that I prefer to work with symbol catalogs with all their features)
Thanks again
