Question on Copying to new map
I have a complex map that I've imported a lot of fill styles into. I want to copy just the floor to a new map (it uses the style that the floor came from). However, when I try to just copy the floor, it carries ALL of fill styles with it. I don't want all of those fills in the new map since I plan to import other fills and the number of fills make searching through then a real hassle.
Hope that makes sense.
Is it possible or do I really have to delete the unwanted fills one by one?
<blockquote><cite>Posted By: Monsen</cite>Do note that it is easier to delete the fills in the source map BEFORE copying the entity, since you can simply delete them all without having to filter out which ones to delete and which ones to keep,...</blockquote>
I hadn't thought of doing it that way. Great tip! Thanks!
