Texture Effect Bound to Bevel
So I was playing around trying to get the effects on my map border correct. I got the bevel the way I want it, then I went and added a texture effect (using the sample concrete) and while playing with that I noticed that the texture effect would not go away even when I turned off the texture effect. I even deleted the texture effect and exited CC3+.
I have found that whenever I turn on a bevel effect (even if I delete and re-create the effect) the texture comes back. Screen shot examples to follow. Any ideas?
The solution to this is to use an intermediate sheet in between the two, with a copy of the top entity, but in a solid color not in the texture at all, such as pink. This intermediate sheet should not have any effects, and will not be visible in the final drawing since it will be covered up by the identical entity on top of it.
