Edit Symbol Properties?
I have finally organized a bunch of random symbols I've acquired from various sources and put them into symbol catalogs. Now I want to go back in and adjust some. For example the catalog FURNITURE -- there might be 100 symbols in the catalog but say 8 are rugs and 4 are curtains. When I created the symbol catalog I checked the FORCE TO SHEET and made the sheet SYMBOLS*. Now I want to change some so that the rugs are forced to sheet SYMBOLS FLAT, curtains to SYMBOLS WALL, etc.
1. How do I go about doing that?
2. Can I edit multiple symbols at once, or is it a one-by-one deal?
Thanks so much. I looked through the TOME and saw the section on editing symbols, but it was more on changing the actual image, which is not what I want to do.
OH! And...
3. How do I gather groups of symbols within a catalog so that they appear in a single square in the catalog window with the little + in the corner (sorry, I know I'm not using the proper CC3 terminology for that but I can't think of it right now)? So that the rugs, for instance, would all be under one square and clicking on the + would expand and show them all in the window? Like is often done with multicolored symbols, trees, etc.
Thanks so much!
    I am on my phone right now, so this is just a brief overview, tell me if you need more detail, and I'll provide.
    1. Open up the symbol catalog as a map in the main map window using the regular file --> Open command (as opposed to opening it in the symbol catalog window.
    2. Go to Symbols --> Symbol manger
    3. Select a symbol (you can also hold down ctrl to do multi select), then click options. Here are the options for all your questions.
    edited January 2018
    Just a note to add to Monsen's reply. To group symbols, they must all have the same name and end with a number, or the same name up to a comma, and then be different.
    For example:
    rug 1
    rug 2
    rug 3
    Or
    rug, Persian
    rug, throw
    rug, plain
  • ScottAScottA Surveyor
    Alrighty, so once I do my editing and grouping in the Symbol Manager how do I save the changes back into the original symbol catalog? Do I just save it as the original catalog again (say, FURNITURE), and the changes are overwritten into that catalog?
    An update would wipe those changes. Saving the symbol catalog to a different filename would be better.
    There will be no update to this as it is not ProFantasy symbols but stuff I've collected elsewhere. I just need to know how to save changes to symbols in personal catalogs. I don't want to save changes into sub-catalogs as that was the idea of cataloging it all in the first place so that it wasn't all spread out.
    Just hit the save button. There is really no difference from working with a symbol catalog and working with a map (or a template). Only thing to remember is to always load the thing you are working on into the main map window, as loading a symbol catalog into the catalog window only allows you to use it, not modify it.
