Symbol Tool Tip Box
When you go to place a symbol down, there is this box to the right of it that tells you all the different ways to do things. I want to remove it because It is hindering my placement of items since sometimes I can't see half of the symbol.
I could really use some help on this, it has left me quite frustrated as I know it's pretty simple. However, I've read the guide, looked through the help section, went through all my options on the program, and searched all over google and found nothing on it.
To remove the floating prompt, select Tools > Options from the menu bar and then uncheck the Display Floating Prompt checkbox in the Options dialog.
The floating prompt will be gone, but remember to keep an eye on the command prompt at the bottom of the screen now. The prompt often provides important information regarding whatever command you're using.
I hope that helps!
Cheers,
EDIT: Ninja'd by Dogtag...Well played sir!
