Source Maps and CC3+
UKgnome
Newcomer
Is it possible to export the plans from the exe file so they can be opened in CC3+
Or is it not possible at all.
When I do get them and load into CC3+ do I run ffix as a command line macro or is ffix a program that I run externally to CC3+ or is there a tutorial somewhere that I should go off and read
thanks
FFIX is a command line command in CC3+, although I don't think it will do much good for the source maps maps, as these are all in vector format anyway.
Edit: Make sure you use the original installers for the products, not the CC3 compatibility update ones, they look specifically for CC3. And DON'T let the original installers install anything inside your CC3+ directory, they will bind it, believing it is CC2.
