toggle menu
Sign In
Register
Sign In
Register
Sign In
Register
Home
Community Support
Cannot Use Pre-Defined |Templates
Ancellus
February 2009
in
Community Support
Select New Sheet, New Drawing Wizard splash appears.
Select Pick Pre-defined Template,
Share on Facebook
Share on Twitter
Ancellus
February 2009
I can call uyp the splash screen with Pre-defined Templates but clicking on them does not alter the default starting map. I can use the New Map and select Decide Settings Myself ... this all works fine.
Share on Facebook
Share on Twitter
Monsen
Administrator
🖼️ 82 images
Cartographer
February 2009
Have you installed the latest patch (Patch 7, brings your CC3 version to 3.24). It is available from your
Registration Page
Share on Facebook
Share on Twitter
JimP
🖼️ 280 images
Departed Legend - Rest in Peace
February 2009
When you load a template. type 'new' at the command line. That loads the template and it will be your default template until you change it.
Share on Facebook
Share on Twitter
Ancellus
February 2009
Thanks Monsen - the patch seems to have fixed things.
Share on Facebook
Share on Twitter
Sign In
or
Register
to comment.
