DD3 Crash to Desktop
                    I was working with DD3 this afternoon to do a building layout.  I wanted to share the finished map with a friend who doesn't have the program, so I saved a fcw copy, then clicked on "Save as JPG file".  I received the following error message:
"FCW32.exe has stopped working:
Problem signature
Problem Event Name: APPCRASH
Application Name: fcw32.exe
Application Version: 0.0.0.612
Application Timestamp: 476086d3
Fault Module Name: Effects.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 48e52dab
Exception Code: c0000005
Exception Offset: 0000fb61
OS Version: 6.0.6001.2.1.0.768.2
Locale ID: 1033
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
Extra information about the problem
Bucket ID: 973068598"
I am running the program on Win Vista 32-bit
Problem signature
Locale ID: 1033
I too am on Vista.
1) Clicking the "sheet and effects" button, and checking "Activate sheet effects"
2) Issuing the EFFECTSON command line command (EFFECTSTOG toggles between on and off, and EFFECTSOFF turns them off)
But I would recommend you test it out to see if it is a possibility.
Does CC3 crash when it is actually saving the file or right after you choose where to save it? If it crashes right after you choose, try saving it to a different drive and see if that helps. It's kind of a longshot, but it's another possibility.
