re-install pretty much complete/quick question
All right, I've gone through the headaches of pretty much a complete reinstall. For the most part everything's back to normal. I have a couple of minor glitches to work out, but I already have help on that.
I do have one quick question. Most of us have gotten into copyrighting our work. I put the copyright line on every map I make. I now have to set that back up. If I set up the copyright on the first map I make after the reinstall, will it stay there in the correct line? Is there a way to make it a permanent fixtures in the map creation window? It's been so long, I've forgotten.
You could edit the templates and add it in there to have it pre-placed when starting a new map, but you would need to do this to every template you wish to use, as agian, this would be on a per-template basis, and not a global one.
