I know there's a way to make the copywrite symbol ie. the c inside the circle, but I can't remember how to do it. Can someone refresh my memory please?
Just a quick supplementary note to what jslayton said. The numbers need to be entered via the numeric keypad (as he mentioned). Using the number row on the main keyboard won't do it.
This should work anywhere you can type text, including CC3+ text entities. It requires that the font used actually have the symbol though, not all fonts bother defining symbols besides plain letters and numbers, especially fancy fonts.
Even if you forget, as Monsen mentioned, the Character Map utility is your friend. In Windows 7 (and probably later, but I happily don't know) you can usually find it in Programs>Accessories>System Tools.
Posted By: thehawkWindows 7 and previous: click Start then Run or press the Windows Key and R then type charmap in the box that comes up and press the enter key.
In Windows 10, you get it by typing "Character Map" into the search box. It appears to be exactly the same program as previous versions of Windows.
Pretty much the first thing I did when I got my new Win 10 machine last year was to add the Character Map shortcut to my taskbar. I have so many fonts that aren't alphabet characters, I couldn't manage any other way!
